FORUM | LATEST POST | # TOPICS |
Engineering π¬π§ Discussions about the CODESYS Development System, IEC programming, CODESYS Professional Developer Edition |
License problem gateway by Reinier Geers 32 minutes ago |
5041 |
Runtime π¬π§ Related questions to SoftPLCs e.g. Raspberry Pi, Beaglebone, IoT2000 and other platforms |
Problem with Licenced Software Metrics by eschwellinger 2 days ago |
2096 |
Visualization π¬π§ Realizing operator screens with CODESYS HMI, Targetvisu, Webvisu |
Visualization - table element by damian177 23 hours ago |
886 |
Motion π¬π§ Realizing single or multi axis motion control, CAM, CNC and Robotic applications |
SMC_REGULATOR_OR_START_NOT_SET issue by chir 4 days ago |
432 |
Codesys V2.3 π¬π§ Forum about V2.3 |
Set several bits in WORD by stdenits 3 days ago |
2155 |
Deutsch π©πͺ German forum |
Example_PackML.project benΓΆtigt by jw97ke 3 days ago |
4436 |
Automation Server π¬π§ The Industry 4.0 administration platform for users and operators of CODESYS compatible controllers |
File transfer via visu and codesys automation server by eschwellinger 2024-03-11 |
30 |
Forge π¬π§ Discussions about CODESYS Forge projects and features of the CODESYS Forge website |
Could not be resolved - Library error by codesysjupiter 2024-04-13 |
172 |
16.4 Epis What has it to do with the manufacture? It just a licence more not. So basicly the idee of codesys sucks. 3s acts like its posible to add a license. And then it depence on the manufacturer. Why ?? Its a computer !! has nothing to do with the manufacturer. Most dont what a basic licence because they have to pay for that. 3s is the problem not the manufacture of the hardware. Its like the licence of the raspberry pi. HMI is not working. Sorry you get a refund. Why suggest that its possible...
most important information are missing: Which CODESYS Version? Which runtime version? Which plc type (manufacturere).. Not all plc manufacturer already support application based licenses. From your pictures I see you have activated 4 axis Motion (which is an applications based license type) does only work on plc's which do support this.
Hi, eschwellinger, I have the same problem, but I can not resolve the problem following this forum. There are my situation: pi@RevPiXXXX:~ $ uname -a Linux RevPiXXXX 5.10.120-rt70-v7l #1 SMP PREEMPT_RT Thu, 28 Jul 2022 10:36:48 +0200 armv7l GNU/Linux After "top": It looks like runtime is not running. One more piece of information to refer to, when I reboot the device it is possible to scan the device. Looking forward your reply.
Hello. thanks for your help! you saved my life.
Hello. how can I do this but whit variables? I'm triying but i dont why, the result missed the decimals. this is my program: var var1: REAL; var2: REAL; var3: REAL: end_var var1:=100; var2:=40; var3:= var1 / var2; I would expect the value of var3 will be 2.5, but I have only 2 can you help me please.
I bought and installed SoftMotion Light now. When I try to add a SoftMotion Light Axis to my stepper drive and I go online it shows: "The license is missing or invalid". See picture What am I doing wrong? This is the right way right? First add your EtherCat XML-File from your stepper driver and then add the SoftMotion Light axis right? Thanks for your help esave
By browser is not working. Tim suggestet to use Codesys and stick in the laptop. Thats working. But now with a stick with licence but no running motion.
I'm looking for a function block in Codesys 3.5 that has 3 inputs and one output. one input for toggling on and off one input for on one input for off all controlling the same output. does this exist or will I need to make my own function block? thanks
I'm looking for a function block in Codesys 3.5 that has 3 inputs and one output. one input for toggling on and off one input for on one input for off all contorlling the same output. does this exist or will I need to make my own function block? thanks
I'm looking for a function block in Codesys 3.5 that has 3 inputs and one output, one for toggling on and off, one for on and one for off. does this exist or will i need to make my own function block? thanks
