FORUM LATEST POST # TOPICS
Engineering πŸ‡¬πŸ‡§
Upgrade from codesys 3.5.19 to 3.5.20
by pethun
51 minutes ago
5030
Runtime πŸ‡¬πŸ‡§
Codesys 3.5.12 Module not Found
by koehler
3 days ago
2093
Visualization πŸ‡¬πŸ‡§
Text List Fallback Value
by dkugler
2 days ago
883
Motion πŸ‡¬πŸ‡§
SMC_REGULATOR_OR_START_NOT_SET issue
by eschwellinger
1 day ago
432
Codesys V2.3 πŸ‡¬πŸ‡§
Forum about V2.3
CAA Library Function
by mmpl
4 days ago
2154
Deutsch πŸ‡©πŸ‡ͺ
German forum
SPI_master.transferExt
by btt93
5 hours ago
4435
Automation Server πŸ‡¬πŸ‡§
by eschwellinger
2024-03-11
30
Forge πŸ‡¬πŸ‡§
by codesysjupiter
2024-04-13
172
Recent Activities
    CODESYS Forge
  • pethun posted a comment on discussion Engineering πŸ‡¬πŸ‡§
    Hi We upgraded our ptoject from 3.5.19 to 3.5.20 but we get an error message in the latest version. We made our own trend function and its related to this we get error message: Trend_Menu Device: PLC Logic: Application: C0032: Cannot convert type 'RTS_SYSTIMEDATE(systimertc, 3.5.20.0 (system))' to type 'RTS_SYSTIMEDATE(systimertc, 3.5.17.0 (system))' The variables are defined as follow: start : SysTimeRtc.SYSTIMEDATE; end : SysTimeRtc.SYSTIMEDATE; The code that creates the error is the variable start...
  • tib0r posted a comment on discussion Engineering πŸ‡¬πŸ‡§
    I was looking for a transpiler from some more widely used general programming language into ST. It was not easy but I found this :) https://forge.codesys.com/tol/c2iec/home/Home/ Does anybody use it for a programm/library of a couple of hundred lines or more? How does one go about using the output? Is there a β€œconverter” into the Codesys IDE? PLCOpenXML? Would there be interest in this? tib0r
  • btt93 posted a comment on discussion Deutsch πŸ‡©πŸ‡ͺ
    Kann mir bitte jemand helfen. Ich brauche auch eine Verbindung von einem Pixtend V2 L mit Codesys zu einem Arduino. Hab schon alles probiert bekomme aber keinen Datenaustausch zu stande
  • wollvieh wollvieh posted a comment on discussion Engineering πŸ‡¬πŸ‡§
    https://faq.codesys.com/plugins/servlet/mobile?contentId=106889218#content/view/106889218
  • dkugler posted a comment on discussion Engineering πŸ‡¬πŸ‡§
    you try to convert a WORD with BYTE_TO_HEX directly? Using https://de.helpme-codesys.com/ lead to the SM3_shared lib. There is a function: https://content.helpme-codesys.com/en/libs/SM3_Shared/Current/SM3_Shared/StringFormat/Word_To_HexString.html
  • eschwellinger eschwellinger posted a comment on discussion Motion πŸ‡¬πŸ‡§
    which drive ? which drivers is used? ds402generic?
  • DavidBo posted a comment on discussion Engineering πŸ‡¬πŸ‡§
    I try with BYTE_TO_HEXinASCII but I cant get it right. How do I convert a word value like 15432 to the HEX text string '3C48'
  • chir posted a comment on discussion Motion πŸ‡¬πŸ‡§
    Hello everyone! I faced the error SMC_REGULATOR_OR_START_NOT_SET using InoProShop (Inovance IDE). This error occured then I enable MC_Power block. The output BUSY is TRUE constantly.. The description of this error in documentation - "Controller enable not done or brake applied". Maybe someone know how to solve this problem
