FORUM LATEST POST # TOPICS
Engineering πŸ‡¬πŸ‡§
License problem gateway
by Reinier Geers
59 minutes ago
5041
Runtime πŸ‡¬πŸ‡§
Problem with Licenced Software Metrics
by eschwellinger
2 days ago
2096
Visualization πŸ‡¬πŸ‡§
Visualization - table element
by damian177
23 hours ago
886
Motion πŸ‡¬πŸ‡§
SMC_REGULATOR_OR_START_NOT_SET issue
by chir
4 days ago
432
Codesys V2.3 πŸ‡¬πŸ‡§
Forum about V2.3
Set several bits in WORD
by stdenits
3 days ago
2155
Deutsch πŸ‡©πŸ‡ͺ
German forum
Example_PackML.project benΓΆtigt
by jw97ke
3 days ago
4436
Automation Server πŸ‡¬πŸ‡§
by eschwellinger
2024-03-11
30
Forge πŸ‡¬πŸ‡§
by codesysjupiter
2024-04-13
172
Recent Activities
    CODESYS Forge
  • Reinier Geers posted a comment on discussion Engineering πŸ‡¬πŸ‡§
    16.4 Epis What has it to do with the manufacture? It just a licence more not. So basicly the idee of codesys sucks. 3s acts like its posible to add a license. And then it depence on the manufacturer. Why ?? Its a computer !! has nothing to do with the manufacturer. Most dont what a basic licence because they have to pay for that. 3s is the problem not the manufacture of the hardware. Its like the licence of the raspberry pi. HMI is not working. Sorry you get a refund. Why suggest that its possible...
  • eschwellinger eschwellinger posted a comment on discussion Engineering πŸ‡¬πŸ‡§
    most important information are missing: Which CODESYS Version? Which runtime version? Which plc type (manufacturere).. Not all plc manufacturer already support application based licenses. From your pictures I see you have activated 4 axis Motion (which is an applications based license type) does only work on plc's which do support this.
  • yongchaow posted a comment on discussion Engineering πŸ‡¬πŸ‡§
    Hi, eschwellinger, I have the same problem, but I can not resolve the problem following this forum. There are my situation: pi@RevPiXXXX:~ $ uname -a Linux RevPiXXXX 5.10.120-rt70-v7l #1 SMP PREEMPT_RT Thu, 28 Jul 2022 10:36:48 +0200 armv7l GNU/Linux After "top": It looks like runtime is not running. One more piece of information to refer to, when I reboot the device it is possible to scan the device. Looking forward your reply.
  • benitohb modified a comment on discussion Engineering πŸ‡¬πŸ‡§
    Hello. thanks for your help! you saved my life.
  • benitohb posted a comment on discussion Engineering πŸ‡¬πŸ‡§
    Hello. how can I do this but whit variables? I'm triying but i dont why, the result missed the decimals. this is my program: var var1: REAL; var2: REAL; var3: REAL: end_var var1:=100; var2:=40; var3:= var1 / var2; I would expect the value of var3 will be 2.5, but I have only 2 can you help me please.
  • esave posted a comment on discussion Engineering πŸ‡¬πŸ‡§
    I bought and installed SoftMotion Light now. When I try to add a SoftMotion Light Axis to my stepper drive and I go online it shows: "The license is missing or invalid". See picture What am I doing wrong? This is the right way right? First add your EtherCat XML-File from your stepper driver and then add the SoftMotion Light axis right? Thanks for your help esave
    By browser is not working. Tim suggestet to use Codesys and stick in the laptop. Thats working. But now with a stick with licence but no running motion.
  • User1997 modified a comment on discussion Engineering πŸ‡¬πŸ‡§
    I'm looking for a function block in Codesys 3.5 that has 3 inputs and one output. one input for toggling on and off one input for on one input for off all controlling the same output. does this exist or will I need to make my own function block? thanks
    I'm looking for a function block in Codesys 3.5 that has 3 inputs and one output. one input for toggling on and off one input for on one input for off all contorlling the same output. does this exist or will I need to make my own function block? thanks
  • User1997 posted a comment on discussion Engineering πŸ‡¬πŸ‡§
    I'm looking for a function block in Codesys 3.5 that has 3 inputs and one output, one for toggling on and off, one for on and one for off. does this exist or will i need to make my own function block? thanks
