FORUM LATEST POST # TOPICS
Engineering 🇬🇧
Network Variables not updating
by alex-wall
20 hours ago
5061
Runtime 🇬🇧
Linux ARM64 SL, GPIO Access
by mehmetembedded
2 hours ago
2105
Visualization 🇬🇧
WebVisu flickering
by herbasso88
2 days ago
889
Motion 🇬🇧
Maximum dynamic limits of MC_MoveLinearAbsolute and MC_MoveLinearRelative
by manuknecht
58 minutes ago
437
Codesys V2.3 🇬🇧
Forum about V2.3
How to communicate 2 pcs that are using CODESYS
by guilhermeleao
2 days ago
2158
Deutsch 🇩🇪
German forum
AG Abzug bei Codesys 3
by koehler
3 hours ago
4440
Automation Server 🇬🇧
by eschwellinger
2024-03-11
30
Forge 🇬🇧
by ademarvribeiro
2024-04-29
172
Recent Activities
    CODESYS Forge
  • manuknecht posted a comment on discussion Motion 🇬🇧
    Hello all I use an axis group with two linear axes in a kinematic system. Using MC_MoveLinearAbsolute and MC_MoveLinearRelative, I am trying to realise dynamic movements (set velocity: 1 m/s, set acceleration: 30 m/s^2) with the highest possible jerk, as I want to compare this with a movement with a trapezoidal velocity profile. However, my measurements show that the axes accelerate with a maximum jerk of approx. 800 m/s^3, even if the value in the function block was set to 10,000 m/s^3. I have already...
  • mehmetembedded posted a comment on discussion Runtime 🇬🇧
    Hello. I am using TI AM64x evaluation board TMDS64EVM. It has 8 leds connected via I2C to SoC.I wanna control them via codesys GPIO device. Is that possible? If so how I can do it. I had no problem installing codesys runtime, and running program on device. But when it comes to GPIO access, It couldn’t make it.
  • koehler posted a comment on discussion Deutsch 🇩🇪
    Hallo zusammen, Gibt es die Möglichkeit einen "AG Abzug" ( Wie bei Siemens S7 zum Beispiel) vom Online Projekt durchzuführen?
  • sbrauns posted a comment on discussion Runtime 🇬🇧
    Hi, I am using Codesyscontrol for linux 4.11 with an USB dongle with license. The log file from codemeter shows a constant error message which repeats every minute: Entry (6000437:8755) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4) with UserLimit API Error 200 (ENTRY NOT FOUND) occurred! The log file from Codesyscontrol itself shows runtime licensed and I experience no other issues. But I am still concerned about the error message in the log file. Does anybody know what...
  • andrej modified a comment on discussion Runtime 🇬🇧
    Hello, I use Codesys RTE 3.5.16.5. If I connect to the PLC I often get the following message: (see printscreen) 1. Channel timeout CMpChannelMgr. 2. Closing connection CmpChannelMgr. Can you tell me, what the meaning of this is? What does the number 1250030,1220020 resp. c400:0a0a:015a:0301 refer to? I could find any information in the online help. Thanks a lot.
  • andrej posted a comment on discussion Runtime 🇬🇧
    Hello, I use Codesys RTE 3.5.16.5. If I connect to the PLC I often get the following message: 1. Channel timeout CMpChannelMgr. 2. Closing connection CmpChannelMgr. Can you tell me, what the meaning of this is? What does the number 1250030,1220020 resp. c400:0a0a:015a:0301 refer to? I could find any information in the online help. Thanks a lot.
  • timl posted a comment on discussion Deutsch 🇩🇪
    Hallo, ich habe eine Control for Linux SL auf der ich einen TCP Modbus Master anlege, mit dem ich einen Slave auslesen möchte. Das Anlegen funktioniert soweit alles, sobald ich beim ModbusTCPSlaveE/A-Abbild in den Channel eine Variable einfüge, damit ich den Channel auslesen kann, kommt es beim übertragen auf die SPS zu einem Ausnahmefehler. Im Anhang noch eine Bilder der Fehlermeldung und der installierten Lizenzen. CODESYS Version ist V3.5 SP19 Patch 4 Meinem Verständnis nach ist die Modbus Lizenz...
  • peterned posted a comment on discussion Motion 🇬🇧
    Thanks Georg, that fixed it.
  • alex-wall posted a comment on discussion Engineering 🇬🇧
    This worked for me. I had four identical PLC's. Three of them worked just fine with 255.255.255.255 as the broadcasting address but the 4th would not update the variables. Changed it to 192.168.x.255 and everything worked.
