FORUM LATEST POST # TOPICS
Engineering πŸ‡¬πŸ‡§
License problem gateway
by eschwellinger
25 seconds ago
5043
Runtime πŸ‡¬πŸ‡§
Problem with Licenced Software Metrics
by valenting
8 hours ago
2096
Visualization πŸ‡¬πŸ‡§
Visualization - table element
by damian177
1 day ago
886
Motion πŸ‡¬πŸ‡§
SMC_REGULATOR_OR_START_NOT_SET issue
by chir
4 days ago
432
Codesys V2.3 πŸ‡¬πŸ‡§
Forum about V2.3
Set several bits in WORD
by stdenits
3 days ago
2155
Deutsch πŸ‡©πŸ‡ͺ
German forum
Example_PackML.project benΓΆtigt
by jw97ke
3 days ago
4436
Automation Server πŸ‡¬πŸ‡§
by eschwellinger
2024-03-11
30
Forge πŸ‡¬πŸ‡§
by codesysjupiter
2024-04-13
172
Recent Activities
    CODESYS Forge
  • eschwellinger eschwellinger modified a comment on discussion Engineering πŸ‡¬πŸ‡§
    I just try to help. Anyway it is a big difference if a Store SL runtime or an oem plc and licence is used. These licenses need to be activated on plc side - so you have dependencies to the version (CODESYS and Runtime Version) Did you ever ask Epis out for this situation? They should know which license fit to their device. Even they should know if the device is capable for Softmotion.
  • eschwellinger eschwellinger posted a comment on discussion Engineering πŸ‡¬πŸ‡§
    I just try to help. Anyway it is a big difference if a Store SL runtime or an oem plc and licence is used. These licences need to be activated on plc side - so you have dependencies to the version (CODESYS and Runtime Version) Did you ever ask Epis out for this Situation? They should know which License fit to their device. Even they should know if the device is capable for Softmotion.
  • scoob posted a comment on discussion Engineering πŸ‡¬πŸ‡§
    Hello, I have been trying to use the ModbusFB functions so I can put some code into libraries, but it seems to be very slow for me. I have a Modbus device with 100ms registers. I previously setup 10 channels in the 'traditional' Modbus Slave with channels and mappings - and set a cyclic trigger at 100ms - this worked fine. I then tried the ModbusFB example, and setup reading the same 10 blocks of modbus addresses, copying the example and putting all of the requests into an array and triggering the...
  • valenting posted a comment on discussion Runtime πŸ‡¬πŸ‡§
    Hi, I tried with another project, using codesys SP20 with the latest visualization installed, I can install the application on my device but it doesn't work I get an exception "invalid license metrics" and the app won't run See attached the metrics in project and allowed by license, and the logs What am I supposed to do ? Everything is in the newest version and the values are lower than allowed and nothing works...
  • cpoi posted a comment on discussion Engineering πŸ‡¬πŸ‡§
    Hello, I using the EL6900 module with EL 1904 and EL2904 on Ethercat, and I have a ComErr on the EL6900. The FSoE Adresse : EL6900 = 1 EL1904 = 11 EL2904 = 15 Any suggestion? Thanks a lot in advance.
  • Reinier Geers posted a comment on discussion Engineering πŸ‡¬πŸ‡§
    16.4 Epis What has it to do with the manufacture? It just a licence more not. So basicly the idee of codesys sucks. 3s acts like its posible to add a license. And then it depence on the manufacturer. Why ?? Its a computer !! has nothing to do with the manufacturer. Most dont what a basic licence because they have to pay for that. 3s is the problem not the manufacture of the hardware. Its like the licence of the raspberry pi. HMI is not working. Sorry you get a refund. Why suggest that its possible...
    most important information are missing: Which CODESYS Version? Which runtime version? Which plc type (manufacturere).. Not all plc manufacturer already support application based licenses. From your pictures I see you have activated 4 axis Motion (which is an applications based license type) does only work on plc's which do support this.
  • yongchaow posted a comment on discussion Engineering πŸ‡¬πŸ‡§
    Hi, eschwellinger, I have the same problem, but I can not resolve the problem following this forum. There are my situation: pi@RevPiXXXX:~ $ uname -a Linux RevPiXXXX 5.10.120-rt70-v7l #1 SMP PREEMPT_RT Thu, 28 Jul 2022 10:36:48 +0200 armv7l GNU/Linux After "top": It looks like runtime is not running. One more piece of information to refer to, when I reboot the device it is possible to scan the device. Looking forward your reply.
  • benitohb modified a comment on discussion Engineering πŸ‡¬πŸ‡§
    Hello. thanks for your help! you saved my life.
