FORUM | LATEST POST | # TOPICS |
Engineering π¬π§ Discussions about the CODESYS Development System, IEC programming, CODESYS Professional Developer Edition |
License problem gateway by eschwellinger 14 seconds ago |
5043 |
Runtime π¬π§ Related questions to SoftPLCs e.g. Raspberry Pi, Beaglebone, IoT2000 and other platforms |
Problem with Licenced Software Metrics by valenting 8 hours ago |
2096 |
Visualization π¬π§ Realizing operator screens with CODESYS HMI, Targetvisu, Webvisu |
Visualization - table element by damian177 1 day ago |
886 |
Motion π¬π§ Realizing single or multi axis motion control, CAM, CNC and Robotic applications |
SMC_REGULATOR_OR_START_NOT_SET issue by chir 4 days ago |
432 |
Codesys V2.3 π¬π§ Forum about V2.3 |
Set several bits in WORD by stdenits 3 days ago |
2155 |
Deutsch π©πͺ German forum |
Example_PackML.project benΓΆtigt by jw97ke 3 days ago |
4436 |
Automation Server π¬π§ The Industry 4.0 administration platform for users and operators of CODESYS compatible controllers |
File transfer via visu and codesys automation server by eschwellinger 2024-03-11 |
30 |
Forge π¬π§ Discussions about CODESYS Forge projects and features of the CODESYS Forge website |
Could not be resolved - Library error by codesysjupiter 2024-04-13 |
172 |
I just try to help. Anyway it is a big difference if a Store SL runtime or an oem plc and licence is used. These licenses need to be activated on plc side - so you have dependencies to the version (CODESYS and Runtime Version) Did you ever ask Epis out for this situation? They should know which license fit to their device. Even they should know if the device is capable for Softmotion.
I just try to help. Anyway it is a big difference if a Store SL runtime or an oem plc and licence is used. These licences need to be activated on plc side - so you have dependencies to the version (CODESYS and Runtime Version) Did you ever ask Epis out for this Situation? They should know which License fit to their device. Even they should know if the device is capable for Softmotion.
Hello, I have been trying to use the ModbusFB functions so I can put some code into libraries, but it seems to be very slow for me. I have a Modbus device with 100ms registers. I previously setup 10 channels in the 'traditional' Modbus Slave with channels and mappings - and set a cyclic trigger at 100ms - this worked fine. I then tried the ModbusFB example, and setup reading the same 10 blocks of modbus addresses, copying the example and putting all of the requests into an array and triggering the...
Hi, I tried with another project, using codesys SP20 with the latest visualization installed, I can install the application on my device but it doesn't work I get an exception "invalid license metrics" and the app won't run See attached the metrics in project and allowed by license, and the logs What am I supposed to do ? Everything is in the newest version and the values are lower than allowed and nothing works...
Hello, I using the EL6900 module with EL 1904 and EL2904 on Ethercat, and I have a ComErr on the EL6900. The FSoE Adresse : EL6900 = 1 EL1904 = 11 EL2904 = 15 Any suggestion? Thanks a lot in advance.
16.4 Epis What has it to do with the manufacture? It just a licence more not. So basicly the idee of codesys sucks. 3s acts like its posible to add a license. And then it depence on the manufacturer. Why ?? Its a computer !! has nothing to do with the manufacturer. Most dont what a basic licence because they have to pay for that. 3s is the problem not the manufacture of the hardware. Its like the licence of the raspberry pi. HMI is not working. Sorry you get a refund. Why suggest that its possible...
most important information are missing: Which CODESYS Version? Which runtime version? Which plc type (manufacturere).. Not all plc manufacturer already support application based licenses. From your pictures I see you have activated 4 axis Motion (which is an applications based license type) does only work on plc's which do support this.
Hi, eschwellinger, I have the same problem, but I can not resolve the problem following this forum. There are my situation: pi@RevPiXXXX:~ $ uname -a Linux RevPiXXXX 5.10.120-rt70-v7l #1 SMP PREEMPT_RT Thu, 28 Jul 2022 10:36:48 +0200 armv7l GNU/Linux After "top": It looks like runtime is not running. One more piece of information to refer to, when I reboot the device it is possible to scan the device. Looking forward your reply.
Hello. thanks for your help! you saved my life.
